Code chunghop RM 139 for tv sony
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
SOURCE: code chunghop RM 139ES for TV Hyundai
Google the model number of the remote for manual to try to locate possible codes here.
Not all remotes will program and if do likely will not have all needed features the original remote does.
...TV codes; 026 033 043 159 160 170 175 212 215 702 703 716. chunghop rm 109e code ...
