See following link to identify your timer with instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
Rotate dial until current time lines up with arrowhead; when plugged
in, dial rotates
48 segments located on dial; each segment is 1/2 hour
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
If this is not your timer, then add a comment
If you do not want additional free help, take advantage of fixya phone support.
For a price, fixya expert speaks to you via phone while you set timer.
This is the instruction manual for the Utilitech #0148297.
http://pdf.lowes.com/useandcareguides/054732816736_use.pdf
SOURCE: Don't know to set timer
1) Open following page to identify timer for sure
Instructions for Utilitec 0148297 are supposed to be same as Woods 59366
http://waterheatertimer.org/pdf/Woods-59366-manual.pdf
2) If this is not your timer, then stop by Lowes and buy another timer.
Use sharp blade to carefully cut open side of package, and slide out instructions.
Scan instructions into pdf format and post instructions on your website.
Add a comment to this thread with web location of that manual so others can enjoy your generosity.
Put manual back into package and return timer for full refund.
3) See other available Utilitec manuals:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
