Question about Hyundai Car Audio & Video
I have recently purchaes Hyundai i20 with AVN system. I'm not able to play video on it using USB. It feels like hanging the system. Is there any way I can get the user manual for the systm. OR can you tell me how to reset that system to the factory default? It will help me.
  • 3 more comments
  • Anonymous Jan 05, 2011
    I have not received SD card
  • Anonymous Jan 10, 2011
    Great to hear that. Can you please tell me how much time it took to rectify the issue?
    Hey have you received user manual for the AVN system? if yes, is possible to scan some imp pages
  • Arijit Ray
    Arijit Ray Dec 13, 2013
    The issue hasn't been fixed yet. Hyundai clearly said that they are unable to fix the issue as they have no clue what is causing it in the 1st place.
  • Arijit Ray
    Arijit Ray Jun 26, 2014
    Problem not resolved yet. Had to take them to the consumer court.
    New Friend:
Hi Arijit Ray, Thanks for sharing. For me I also had to undergo the same ordeal. Finally after 5 visits to the dealer, they replaced the entire wiring harness from another vehicle. Since then, I stopped playing any movie files in the AVN system. Of course the GPS works good. But there seems to be some serious issue with your vehicle. None of that you mentioned i have undergone and i see that brakes, steering everything else works fine. So in the end, I had to end up paying 70k more for this AVN system which never works (plays Movie files) as per the recommendations. But in my experience MP4 & MP3 file formats are supported.
Rajesh.
Posted on Mar 05, 2013
  • Arijit Ray
    My problem is still unresolved after 3 years. I have submitted a case in the consumer forum. Also, try the brakes on wet or uneven roads (where there is less traffic). Notice if the braking distance is significantly increased. I have interacted with a lot of i20 ABS users who have complained that the brakes fail to respond on uneven and wet surfaces.
This problem seems to be common in Hyundai i20 with AVN sold in India.
My i20 with AVN also has the same problem. The Hyundai dealer is not able to solve this issue. He has replaced the AVN system also, with no luck.
I suggest you contact your dealer to rectify this issue.
regards, Pradeep
Posted on Jan 03, 2011
  • 10 more comments
  • Anonymous Jan 04, 2011
    Yes. I remember video playback worked only once when car was in dealer docyard. But after that it is not working. Even photo viewer is not working. As this system runs on windows embeded OS. This gets hanged
    Hey Pradeep, Have you received navigation SD card
  • Pradeep Chennamale Jan 05, 2011
    Yes, SD card came with the car. it was in the cover alongwith the system warranty card
    The system worked twice on my car. after that it stopped.
    My car is with the dealer for the last 3 days. They have dismantled the system and sent it to Nippon (system supplier) for rectification.
    I suggest you contact your dealer, this problem wont get solved on its own.
    will let you know once the problem is solved
    I have not received the SD card
  • Pradeep Chennamale Jan 09, 2011
    My car's AVN issues have been sorted out. All functions are now working. Trident Hyundai co-ordinated with the system supplier and rectified the problem.
  • Pradeep Chennamale Jan 10, 2011
    Trident Hyundai had my car from 3rd January till 8th January......
  • karthikpanic Feb 20, 2011
    hi pradeep,
    Am planning to buy i20 with AVN. What should i check in AVN before i receive it from the dealer. Should i carry a USB drive with videos and songs? Wat formats should i be using?
  • Arijit Ray
    Arijit Ray Apr 16, 2011
    I have a i20 with AVN. I am facing similar issues. The MP3 or Video being played from the USB drive gets hanged and then the system reboots. I have noticed that it happens randomly. I suspect that it is a problem of loose connection as the Navigation system keeps working. I am curious how someone' problem was solved. Can you please shed some light on this? Feel free to email me at arijit.ray81@gmail.com
  • sanrajraesh Jun 24, 2011
    Even I have faced the same problem with my AVN system. It is very frustrating that the system does not read Movie files. With lots of difficulty and after making 5 trips to Hyundai dealer, they replaced the complete USB port and the wiring harness from another vehicle in their yard. No idea how to update the OS, since MOBIS/Hyundai has not provided the SD card with the car.
    My recommendation is do not go with the AVN model. Of course GPS works great with MAP MY INDIA. The problem is with movie files. Can anyone clarify which are the formats supported. I think AVI extensions read, I have personally tested it, but as everyone felt, the movie freezes after some time and then starts playing on its own. I think Hyundai/MOBIS is not equipped to do the service with the required technical knowhow for this AVN system.
    You can email me at sanraj.rajesh@gmail.com if you have some more information on AVN system from Hyundai MOBIS
  • Arijit Ray
    Arijit Ray Feb 19, 2013
    Pradeep, Sanraj, has this problem been resolved? If not, please get in touch with me immediately at arijit.ray81@gmail.com .. I have some important news for you folks...
  • Arijit Ray
    The problem can't be solved. Hyundai released this variant without proper testing and this has been confirmed by them. The only option is to replace the vehicle as it is defective.
    New Friend:
    Problem Solver:
  • 16 Answers
This is to inform you that I purchased a Hyundai i20 ASTA AVN (Petrol) vehicle on 30th March 2011 with the registration number MH 12 GR 9013 from Kothari Hyundai, Pune.
This vehicle came as a limited edition vehicle with Audio-Visual Navigation (AVN) System. However, soon after taking delivery of this vehicle I realized that the state-of-art AVN system which made this vehicle the costliest of the i20 variants at that point of time was defective. The system continually stopped working and restarted. I reported this issue immediately on 5th April 2011 and received a reply from them on 7th April 2011 and was advised to get the vehicle to the workshop where this issue would be taken care of and corrected. However, after repeated visits to the workshop in Pune, this issue remained un-resolved.
I realised that this issue was becoming more problematic day by day and was infecting other adjoining systems also. The system now stopped working every time I honked, took a turn and even when un-provoked. At times the system was starting up on its own from a "Switched Off" state. I came across blogs where other buyers have faced similar issues with this variant of i20. I have also faced major issues with the power-steering locking up on two separate occasions and the brakes failing to work adequately on several occasions narrowly escaping a major accident each time while driving this vehicle with my family. I believe these issues are related as they are electrical in nature. When I visited Hyundai workshop at Pune umpteen times after being advised by their senior officers for the same, they were unable to diagnose or verify any issues with the power-steering or brakes and often dismissed the issues as minor. I now not only feel unsafe to drive this car but it is extremely dangerous to drive this car in public with the above defects.
After shifting to Siliguri (West Bengal) due to my father's sudden demise I took this matter up with the Hyundai workshop at Dagapur, Siliguri. They tried their level best to resolve this issue in consultation with their technical department and regional offices at Kolkata and New Delhi. They replaced every part connected to the system multiple times including the entire wiring harness, USB port, the AVN system itself, and parts in the steering column. Hyundai had deployed their senior technicians from their R&D department to come and take a look at the system as well and try various other options possible, but the issue remained un-resolved. I was informed that there was some sort of electrical interference that was causing this issue. However, Hyundai mentioned their inability to detect the point of origin of this interference, diagnose it and correct it. They also confessed that in reality this particular model of the vehicle was released without being properly tested.
Having come to this point, I was asked my choices as compensation. I demanded that Hyundai replaces my car with a lower variant of the same model as this one fails to live up to its reputation, expectations and as advertised. I feel cheated to have spent my hard earned money on it. I also demanded that the difference of prices between the two variants be refunded to me with interest. I wanted my new vehicle to include the accessories and various car treatments (under-body, Teflon, engine coat and Anti-UV treatment of glass) for which I paid extra when I purchased this vehicle. I would also like to claim compensation for the time spent from my professional work schedule, mental harassment I went through during this period of two, the fuel that was consumed while taking unprecedented trial runs and for the taxi charges I paid as I was often left without a vehicle during the futile attempts to resolve the issues.
Posted on Feb 19, 2013
  • Arijit Ray
    Arijit Ray Mar 05, 2013
    Folks FYI... the EBD on i20 is not properly tuned. The rear wheel only applied 5% of braking even when there is no traction on the front tires... this is across all i20 variants with ABS. In a situation where the front tires are on a slippery surface on in the air (like in bumpy roads) and you brake.. the car will feel like there are no brakes at all and it keeps moving at the same speed unlike vehicles without ABS+EBD ...
    This is extremely dangerous as the car will not stop within the distance you assume it will...
    If you do not believe me, try this on an empty road. I have faced this many many times and narrowly escaped major accidents.
    Technically speaking.. EBD is supposed to distribute the brake force in such a way that the car stops.. in the case where there is no traction in the front wheels, the rear wheel braking is supposed to more important.. that's what EBD is for.. not only to balance left and right traction...
SOURCE:
How do I remove the battery from a Hyundai i20?
This video is for a different model, but shows a socket with extension to release the bar that holds the battery in.
https://www.youtube.com/watch?v=DWlHE6ShvMI
Nov 03, 2015 | 2010 Hyundai i20 1.2i
My 2011 Hyundai i20 usb port isn't working? Can someone help me?
Hi Kate, Try a 4GB USB stick formatted in FAT32 and having only MP3 files. Some Hyundai vehicles seem to have a problem reading USB sticks above 4GB and the makes of pen drives is an issue too.
Oct 25, 2014 | 2010 Hyundai i20 1.2i
Usb reading error i20
have issues with my Hyundai i20 where i cannot play songs with my Iphone
Oct 25, 2012 | 2011 Hyundai i20 1.2
Changing the language on eclipse avn 076 from japanese to english
If u got anything plz let me know as well.
Amritmutti01@icloud.com
May 11, 2012 | Car Audio & Video
Fuse box diagram for hyundai i20 2010
On this website you find fuse box diagram and description for Hyundai i20 (2010)
http://www.autogenius.info/hyundai-i20-2010-fuse-box-diagram
Apr 18, 2012 | 2010 Hyundai i20 1.4i
I have recently purchased a Hyundai i20 with AVN system. The USB port does not read music or videos. It appears that the USB port and AVN system are not compatible. Has anyone else encountered a system...
Hi Pradeep,
To be able to read data (music, video, etc) off the USB you need to format it accordingly:
0. The USB should have data on the boot drive itself 1. The USB needs to be formatted correctly (FAT32 with allocation units of 512KB).
Try this - should work.
Avi (Another i20 AVN User)
Jan 03, 2011 | GPS
Car Audio & Video Logo
1,135 people viewed this question
Top Hyundai Car Audio & Video Experts
Douglas Thorburn
Lawrence Oravetz
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
