Back to:
Tags:
U-Line BI-95
How to replace the ice maker unit.
posted by specialist19 on Jul 08, 2008
My BI95 ice maker is not making much ice. I have replaced the thermostat. That did not help. The tem is set to around 20 deg. And i am alsogetting some of the teflon coating off of it in the ice. So i ordered a new unit. Now how does it come out. I think i have removed all of the screws but it will not come out. I also ordered a new door seal. Thanks in advance
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 15, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just RR'd mine. Undo the three screws on the bottom of the metal piece that the ice maker sits on, then the two screws that are horizontle above the . Take of the back, withdraw the termocouple from the tube that goes through the foam, clip the wires (5) leaving enough of a pigtail to crimp a **** splice to the new ones. Withdraw the fill tube. Don't lose the clay that seals the holes through the insulation. Withdraw the ice maker by gently twisting and pulling straight out. Replace in reverse order. Getting the screws back in is a little tricky.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how to replace the ice maker unit.:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
The ice will not dispense in cube or crushed mode. This...
Refrigerators
I have it set to the suggested 37 degrees and it keeps...
Refrigerators
Freezer section is not working
Refrigerators
going slow and making loud clicking noise as it stops and...
Refrigerators
the freezer works fine but the bottom hald won't cool but...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
