SOURCE: My Blue Snowball Microphone doesn't shop up in the
Go to the device manager on your computer, and see that the driver for that mic is turned on or checked.
SOURCE: I've got a new Blue
I had the same problem with my PC and went to http://www.asio4all.com/ where I downloaded and installed the driver and it worked!! I found the site by reading this FAQ (see below) at Blue under Snowball.
(But I still have the same problem with my MAC).
"If you should experience any problems getting the program to recognize the
mic, Adobe recommends the following: If the device does not allow you to record,
then your microphone is not being detected as a valid input device in Premiere
Elements. You can use an open source program called ASIO4ALL, which is a device
driver that essentially wraps existing WDM devices, like USB microphones, as
ASIO-compatible sound devices. Use the following steps to utilize this tool:
SOURCE: Yesterday, when I plugged the
Hi.
Go to Mac audio settings, select and set the input device and the mixer to the same device (your mic),
Set the Mixer/Mux/Lin, line must be set to the be microphone. Ensure that line volume is up.
Check if direct sound is selected in Mac settings, in some case you need to uncheck it.
Let me know in case that does not fix the problem, I will have a look to see if there is any issue that can be related to the Snownball.
the plug where it goes into the mic flip it u have it upside dwn i jus figuered it out
