Question about Xerox WorkCentre M-24 Color Copier
XEROX 5328 COPER
I am going to be moving one of these soon, so I was wondering if any of you know, how much does the Xerox 5328 Copier weigh?
  • Anonymous Oct 13, 2008
    on a Xerox 5318 the wrong toner was added and contaminated the Developer. helping a friend. after vacuuming it all out and adding new Developer. How do I set the new Developer?.
  • 3 Answers
Physical Dimensions / Space Requirements for the 5328 Physical Dimensions / Space Requirements for the 5328
5328 Physical Dimensions :
Weight
110 kg (241 lb)
Length
762 mm (30 inches)
Width
736.6 mm (29 inches)
Height
1067 mm (42 inches)
The following is the area that needs to be free from the side of the machine:
Space Requirements
51 mm (2 inches) from the back of the machine to the wall.
311 mm (12.25 inches) from the right side of the machine. This includes the Bypass Tray if you have one.
305 mm (12 inches) from the left side of the machine. This includes the Sorter if you have one.
610 mm (24 inches) from the front of the machine.
Posted on Dec 10, 2008
    President:
  • 2,072 Answers
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Posted on Jul 08, 2008
SOURCE:
Xerox Copier 5328 Paper jams where the baffle located. Goes through but does not come out. is
Sounds like a fuser problem. Also, because this is a very old model, constant heat over time can warp plastic paper path guides which will cause strange jamming. These issues hare sometimes hare to pinpoint. Why not get a new copier?
Feb 13, 2014 | Office Equipment & Supplies
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
RE is the Xerox 5328 discontinued as a model?
Yes. It has been for some time. Xerox will not service it, but there are many reputable dealers that will. Parts are available and so is service. Just not by Xerox direct.
Oct 31, 2008 | Xerox WorkCentre M-24 Color Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox WorkCentre M-24 Color Copier Logo
472 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
