Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
512MB KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP
When i connect the flash drive into my PC it shows the name of flash drive is SKYMEDI not KINGSTON product name..i don't know how it becomes a SKYMEDI USB drive..as of now i can't use the device because i don't know what to do when i'm trying to format the disk it says.."No disk in Drive E..Insert a disk and try again.." and also says "the disk cannot be formatted" but way back year 2007 im using this device but now, i can't use it anymore..pls help me..im willing to wait your reply ASAP to solve this kind of problem..thanx inadvance
  • 8 more comments
  • Anonymous Jul 10, 2008
    get the same today
  • imunoalergia Jul 10, 2008
    My 8GB gets the same bug today
  • marcosF Aug 23, 2008
    same problem with a 1GB data traveller. Today, I have contacted the support service at kingston:
    Problem Desc.:
    I inserted it an a new driver was installed: SKYMEDI
    after this, I cannot access the pendrive, and I cannot format it. It is shown as a zero byte pendrive.
    How long has this part worked?:
    1-2 years
    Have you tried replacing this part?:
    What troubleshooting have you tried?:
    I tried to recover the information using several tools
    I tried to format it from windows and from msdos
    I tried to format it with a low level formatting tool.
    I cannot do anything, because the PC cannot access the pendrive
  • Anonymous Oct 29, 2008
    i have the same problem
  • joe_cgp Nov 24, 2008
    im have 4gb kingstone DT100, this usb deteck on computer as SKYMEDI USB & canot used..
    please the solution
  • Anonymous Dec 14, 2008
    i have 4gb usb KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP problem
  • atif563 Dec 29, 2008
    plz mail at this id# atif563@gmail.com
  • Anonymous Feb 24, 2009
    i used my Kingston 4GB usb drive for almost a year now i found out that it is being detected a SKYMEDI USB device..
    How the hell did that happen?
  • Anonymous Apr 22, 2009
    Hi, I have same problem. 16GB Kingston was changed to SKYMEDI USB DRIVE. One evening i have seen the movie from usb disk and i have correctly switch off my computer. At the morning when I switched the computer on USB was inacessible.
  • Anonymous Apr 23, 2009
    i have the same problem with my usb flash kingston 4G
    it happen since my friend unplugged it with force
    since then it just recognize but inaccessible
    i try to format but it doesn't work
    i have try some solution above but it doesn't work either
I think that I have a similar problem (and a potential solution)
1. My thumb drive is 4GB "super talent", and I have used it for about 2years
2. Suddenly, it show up as "REMOVABLE" SKYMEDI USB DEVICE (!)
3. I tried "google" for answer... and did not get further
4. Finally, I righ click on "my computer" -> select "manage" the "computer management" MMC windows open
4.1 I tried the "Disk Management" and it still can not connect to it
4.2 I clicked on "Removable Storage" ... and then I "SKYMEDI..."
4.3. I righ click on the device and select "Task" -> "Free" (thinking ... what can be worst!)
4.4 ... sunddenly ... I see my drive back ... with everything on it....
I hope that this help (... I am guessing that the "removable storage" manager locked this device somehow)
Regards
Posted on Dec 08, 2008
  • 1 more comment
  • hoangledat_q
    hoangledat_q Jul 26, 2012
    Thank you very much!
  • hoangledat_q
  • archangelicf
    archangelicf Oct 22, 2012
    Nothing happens.... still SKYMEDI and still untouchable
I tried dozens of programs and finally I could fix the but with this one:
http://rs263.rapidshare.com/files/81282720/6201.rar
sk6201 using the auto-LLF button (low level format)
Posted on Aug 24, 2008
For the guy with PQI drive.
I had this same problem, with an intelligent stick i810.
I gave up for a few weeks, but today I tried my luck with some apps i hadn't tried before.
I FOUND THE SOLUTION at last.
I used SK6281_PDT_20080409.exe for low level format. (other versions of SK6281 did not work at all, nor did 6201 or 6211). After that i could format using the xp format tool (fat32).
the link: http://flashboot.ru/index.php?name=Files&op=view_file&lid=139#139
(or just search for skymedi at flashboot.ru)
Very happy :D
Posted on Nov 22, 2008
Hi folks, ok, happened to me and now I hope I can help. I have a 8gb Data Traveler. I contacted Kensington after reading this and several other posts. Does not look like a real answer yet to recover the drive. But, Kensington said they recognise the drive as a faulty unit and will replace it. Contact them and get a new drive at least. These things are not cheap. They will ask for the number on the side somewhere. So get a magnifier and write it down. All they said really to recover the drive was to try and download some recovery software and see if I can save my files. So I am working on that. I will let you know if I find one that works. I tend to think my files are lost. Good thing I did back up most of it. Just not in the last few months. GOOD LESSON: SAVE MORE THAN ONE COPY IN OTHER PLACES OR DRIVES AND DO IT EVERY MONTH OR MORE!!!
Posted on Jul 04, 2010
  • babznme Jun 20, 2014
    ok found Easeus software. I have used it on bad flash drives that would not read and on hard drives that were formatted. Until a drive is written on again you can still find the files on it. Easeus! Thank you!
My 2gb kingston flesh was running very good suddenly it stoped nd showd removable disk when i tried to formate it itshowed RAW files system nd then an error occoured pls help me im very worried pls tell me at noumannomi29@yahoo.com
Posted on Jan 15, 2011
  • noumannomi29 Jan 15, 2011
    pls help me pls pls
I have the same problem with my 4 GB Kingston
Posted on Nov 09, 2008
Me too i have the same problem i have a PQI Intelligent Drive i810plus..
when i insert my PQI usb it say SKYMEDI UBS
how can i repair this problem.. plz help...
Posted on Sep 23, 2008
Me kingston 8gb have the same problem, somebody help me
Posted on Aug 05, 2008
Me too, is this a virus?
Posted on Jul 10, 2008
2GB KINGSTON USB DATA
2 DAYS AGO WORK BUT TODAY NOT WORK HELP
IM CLICK OPEN BUT ANSWER
(1)..DISK IS NOT FORMATED
THE DISK IN DRIVE I IS NOT FORMATED. DO YOU WANT
TO FORMAT IT NOW? IM CLICK YES
(2)FORMAT REMOVABLE DISK I
CAPACITY
1.86GB
FILE SYSTEM
FAT 32
ALLOCATION UNIT SIZE
DEFAULT ALLOCATION SIZE
VOLUME LABLE
EMPTY
QUICK FORMAT
IM CLICK OK
(3) FORMAT REMOVABLE DISK I
WARNING, FORMATTING WILL ERASE ALL DATA ON THIS
DISK. TO FORMAT THE DISK , IM CLICK OK
(4) FORMATTING REMOVABLE DISK I
THE DISK IS WRITE PROTECTED.
(5) THE DISK IN DRIVE I CANNOT BE FORMATED
PLEASE THIS PROBLEM SOLUTION
SEND AFZALJOKHIO1985@YAHOO.COM
Posted on Aug 30, 2008
2 Suggested Answers
SOURCE:
SOURCE: i can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
Posted on Nov 18, 2008
This device can perform faster ??
Go to device divers and make sure you have the right driver installed...some other download you may have done might have changed the original driver..try to download new driver from original sight
Oct 02, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingston data traveler shows as skymedi drive
You can follow the below commands
got to run
type cmd and press enter
then formatdrive name: and press enter
then it will ask for yes or no
press y
again do the above step once again your drive will be format
Jul 01, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston DT 101 II Usb Device become SKYMEDI USB drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
May 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Feb 20, 2009 | Kingston Technologies 512MB DataTraveler I...
Pc shows the drive is not ready...
Hi anis_shah6,
Try using one of the USB ports on the back of the computer.
Kingston Tech Support
Dec 22, 2008 | Kingston Technologies 512MB DataTraveler I...
Driver 512mb
there you go:
http://74.125.77.132/search?q=cache:-AgCNQmYKncJ:members.driverguide.com/driver/detail.php%3Fdriverid%3D684858+512mb+Kingston+data+traveler+driver+download&hl=ro&ct=clnk&cd=7&gl=ro&client=firefox-a
Dec 14, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
I can't format my 512MB kingston data traveler
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
23,625 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
