LG 37LG30 37 in. LCD HDTV Logo
Posted on Dec 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you use a scart lead or the HDMI lead to conect from the DVD to the tv
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Dec 29, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1540056
Points
28391
HDMI would be prefered but scart is fine.
Hope that helps.
1 Related Answer
Anonymous
  • 135 Answers
  • Posted on Apr 13, 2010
SOURCE: will using a gold hdmi lead as opposed to scart improve picture
only on the hd channels
Hi, I have a Funai vhs dvd combo recorder model drv-b2737 and would like to know how I can set this up with my flat screen tv and what cables would I need to accomplish this. Thank you
This has no HDMI socket so you have a choice of either SCART or SVHS depending on what your TV has. If the TV users HDMI you might want to consider a SCART to HDMI adapter lead.
http://www.ebuyer.com/133106-startech-com-6-ft-hdmi-to-dvi-d-cable-m-m-hdmidvimm6?mkwid=sWA3N2WiH_dc&pcrid=51630194939&pkw=&pmt=&gclid=Cj0KEQiAyuPCBRCimuayhb3qqvwBEiQAgz62kTtKa_YG_1esIQiPgik-Xm5AFxuGZI25r11jA5KJOFwaAjJj8P8HAQ
Plug the SCART to TV in the bottom SCART not the top one!
If you just want a SCART to SCART make certain you get the highest quality ones you can find.
There is an OPTICAL output for the high quality sound. You can connect this via an OPTICAL lead to either a Surround Sound unit if you have one or direct to the TV. Again if it has an OPITICAL lead.
If using make certain the output it is switched on at both ends. You will see a red light if the TV is outputting it, with it unconnected to the VCR.
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Toshiba sd-v295 tunerless DVD VCR Combo To Sony Digital TV Instructions
It will depend on if the Toshiba has an HDMI socket. If it has then the Sony TV will almost certanily have one. Then all you need do is get a HDMI lead and connect the two. The only other way would be via a SCART lead. If the TV has only one SCART and it's being used you can get a SCART Switching Box from places such as Amazon, where you will also get the other cables.
2helpful
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
What is the TV channel set to to play a dvds151 dvd player?
almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Can see no way of connection to terrestrial TV, no scart connection?
easy dose it have rf out? or phono out if you have phono out buy a phono to scart lead to conect
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me ([email protected]) and i send you the best solution i can.
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
