Cigarette lighter plug not working
hopefully nothing serious. if you can, make sure your wires did not burned or got too hot.Visually inspect them. Then, if you have a voltmeter check to see if you getiing power to it. no voltmeter? Go to your nearest auto parts store and ask for a test light.
Back to the lighter, if you have power on the wires or wires leading to the back of the lighter, more than like it you lighter burned out.
No power on the wires? make sure wire did not get fryed or burned, all wires look good? check fuses again.
worst case scenario, can't find problem ? you can run another wire from your fuse box to the lighter.
Thanks for the manual - but it does not say anything about my specific problem with the steamer.
The problem must be inside the steamer kettle or a inside fuse or something alike.
G/
