E-Machines T6528 PC Desktop Logo
julie arnold Posted on Dec 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do to change the boot order in a emachine t6528
Gustavo Ortiz
Level 3:
  • Master 637 Answers
  • Posted on Dec 29, 2010
Gustavo Ortiz
Master
Level 3:
Answers
637
Questions
8
Helped
314348
Points
1811
When the machine are start to boot press F2 before start windows, That is the setup of the Bios and there you can change the boot order
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
T6528
See http://www.manualowl.com/m/eMachines/T6528/Manual/119527 which is the manual for your eMachines T6528 system and has information on replacing hardware components including disk drives.
2helpful
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Is there a space for a second hard drive in emachines T6528
you should have no problem in putting another hdd in to the case you should have space
EMachines Compuer Power
u need a light and a good loop
u will see that the shema is already described in the motherboard its a lil small chart its always locate on the south brige chip near to it
raete me to give u another solution
5.1 vs. 4.1 speakers.
hmmmmm emachines has it w/ 5.1
http://www.emachines.com/products/products.html?prod=T6528
and like you said, will he realy know the diffrence :)
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
