This error is related to several issues. I wish your problem is not with the Firmware. First of all try the following:
If the error still persists, try re-seating all the cartridges and drum including the Fuser Unit. I would also recommend you to clean the printer using a Blower/Vacuum Cleaner (this is not compulsory, but as a remedial so that we can make sure it's not related to minor issues).
If there is a Ram or Memory installed, please check and clean the metallic contacts. If possible try with another Memory stick.
If nothing seems helpful, try the steps mentioned here (Click Here). You can download the same document as Html here (Click Here). It will open up in your browser.
Your last option is to Update the Firmware which is only possible and could be done by a professional..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
The M3035 MFP does not have a check/select button or a menu button
Hi @Kkendric, this post is about HP LJ M3035xs and if I am not wrong, many features are not with M3035 Hope this helps...
M3035xs does not have de check, select or menu... should start with stop and then press 6 and after press start
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
