HP DeskJet 1220c InkJet Printer Logo
Posted on Dec 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install hp 1220c on windows 7 - HP DeskJet 1220c InkJet Printer
Anonymous
Level 3:
President:
  • Master 1,901 Answers
  • Posted on Dec 29, 2010
Anonymous
Master
Level 3:
President:
Answers
1901
Questions
5
Helped
761151
Points
6406
See: HP DeskJet 1220c Drivers
However, HP says that this printer driver is in the Windows 7 OS. Try doing a Windows update.
Here is HP's Windows 7 information page:
HP 1220c and Windows 7
Thanks for using Fixya.
4 Related Answers
Anonymous
  • 67 Answers
  • Posted on Jul 26, 2011
SOURCE: Can't download and install printer
There is no downloadable driver for this printer. You just need to update the Windows 7 list on your computer with the latest update. Here are the instructions from hp:
The drivers for your HP product are already included in the new Windows 7 operating system! You do not need to download drivers to use the product . Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product. With the in-OS The driver located in the Windows 7 operating systemdriver, some of the buttons on the product do not function and some of the advanced product features are not available. For more information about your in-OS driver, and to see workarounds for lost functionality, go to our Frequently Asked Questions below. Install the Windows 7 in-Operating System (in-OS) print driver When you connect your printer to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Step one: Install the in-OS driver Follow these steps to install the in-OS driver in Windows 7. NOTE: The computer must be connected to the Internet for Windows Update to detect and install your product.
  1. Turn the product on.
  2. Connect the USB cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif NOTE: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
  3. Windows 7 detects the hardware and automatically installs the correct driver. A notification displays on your computer to let you know when installation is complete.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use workaround procedures instead. See our Frequently Asked Questions section below. Step two: Print a document Print from any software program to make sure your printer is working correctly.
  1. Open a document in the software application in which it was created.
  2. Click File , and then click Print .
mariem1959
  • Posted on Dec 29, 2007
SOURCE: hp 1220c window xp driver
i updated my driver for my hp1220C on XP after a crash that stopped the valuable print preview function working ...(printer worked but was print immediate - -and no tool box options etc) . i can't believe i found how to fix the driver ... you need to right click the exe file [before running it] dj1074en.exe or whatever ... and 'properties' - 'compatibility' click near 'compatibility mode' 'windows 2000' - then run it ... and voila -- i now have the print preview and all the lovely functions back again!!!! crazy!! took me 3 hours to find this ... it may well work with vista -- to select the windows 2000 option .. don't know that one ... at least until HP update all corectly and clearly
marie
Anonymous
  • 560 Answers
  • Posted on May 01, 2010
SOURCE: I cannot install my hp deskjet 1220c printer in
Hi. Please check your if you have 32-bit or 64-bit system. Download and install the correct driver from HP. Again, please use 64-bit bit drivers for Windows 7 64-bit.
To check if your system is 32-bit or 64-bit, click "START" then right click "COMPUTER" then select "Properties".
Anonymous
  • 417 Answers
  • Posted on Jan 13, 2008
HI goto www.hp.co.uk or www.hp.com and select support and download select the operating system and which printer you are using and the updated driver is available to download.
Hope this helps
Thanks J
HP 1220c driver for windows 8 64 bit
All of the HP drivers for the HP 1220C are available here: http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=19142 . For Windows 8 and higher, the driver should be available through Windows Update. Make sure that the computer is connected to the internet and connect a USB cable between the computer and the printer. The printer should be on. If you do not see any activity, try accessing Windows Update and checking for updates manually.
Note: you do need allow Windows to automatically download driver software. See http://support.hp.com/us-en/document/c01796879 for some of the items to check. Additional steps are here: http://h30434.www3.hp.com/t5/Inkjet-Printing/I-need-a-printer-driver-for-my-Deskjet-1220C-to-use-on/td-p/5485192 .
I hope this helps. Some of the Windows Update steps can be slow.
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
https://123hp.co/hp-deskjet-printer-models
How do i get the Win7 driver for Hp deskjet 1220c printer
Hi
HP doesn't support your device under Windows 7 . Install a Virtual version of XP on your machine :
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
or purchase a Windows 7 compatible replacement device .
Best regards ,
fanaudi .
I have installed HP 1220c printer on windows 7 in several ways. Printer seems istalled OK, when I try to print test page or other, the printer doesn't react. Although the print appears and dissapears...
Unistall any previous you have installed for your device.
The Driver for Your Product Is Included in the Windows 7 Operating System (i.e. Win 7-32bit & 64bit).
Hope it helps.
Hp deskjet 1280 printer driver cd not supporting windows 7 what to do?
Use HP Deskjet 1220C Driver that is inbuilt in Windows 7. Install it manually.
2helpful
Hello I have no custom paper size option in my printer properties OS : windows 7 32bit Printer: HP deskjet 1220C
I would suggest you to uninstall the currently installed Hp Software and printer's driver from your computer and reinstall them. This should fix the issue if there's no problem with your computer like virus or system corrupt etc... Let me know if the problem persists.
Note: Don't forget to restart your computer before you reinstall the programs after it's/they are uninstalled.
Good luck.
Thanks for using FixYa.
I cannot install my hp deskjet 1220c printer in windows 7
4helpful
3answers
109helpful
6answers
1220c driver for windows 7
HP 1220c driver for Win 7 is nit working, need help
k24674
Grand Canyon Tech
Grand Canyon Tech
