Question about Necchi Sewing Machines
I have been looking for a foot-control for my model 524FB to no avail. Any suggestions?
    Genius:
  • 1,788 Answers
Check out www.sewingstyle.com. I saw a foot control for a Necchi 524 there for around $25. I hope it was you are looking for. Good luck
Posted on Dec 29, 2010
SOURCE:
I have necchi sewing machine, that was my mother-inlaw,model no. 524fb.How much is it worth,never used.
FIXYA doesn't give appraisals. That is not what FIXYA is for.
Suggestions include checking similar models for sale on the internet, including EBAY.COM and specialized sewing machine web sites.
May 02, 2018 | Necchi Sewing Machines
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
Jan 10, 2017 | Sewing Machines
Will a 6440 foot pedal and cord work on a 6460 Viking sewing machine
According to this site (although the parts are no longer available), it looks like the same foot control will work on both machines:
Foot Control Cord Viking 4116405 02
Dec 29, 2016 | Sewing Machines
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
Mar 13, 2016 | Brother Sewing Machines
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Where can I purchase Necchi Lydia 3 foot control
Contact this person and see if she can help you
dawn@sewingtime.co.nz
or
enquiries@sewingtime.co.nz
Or use their contact page
http://www.sewingtime.co.nz/contact.html
Then ask where you can get one.
The foot control you use should be readily available at any sewing machine parts supply source. There are models that range in USD from $35.00 to 69.00 for the replacement foot control.
I would look in the yellow pages under sewing machines and parts for a local replacement source not being concerned about brand name when it comes to a foot control other than like connections.
Thanks for using FixYa.
Kelly
Mar 19, 2010 | Sewing Machines
White model 524FB sewing machine
I could not find one - try contacting White's customer service - http://www.whitesewing.com/customer.asp
Mar 07, 2010 | White Sewing 1730 Mechanical Sewing...
Bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
243 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
