Hi, Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Here is a tip that will help you with changing your dryer plug.
heatman101
SOURCE: i need a power plug
Assuming that you need a 220V connector, they can be purchased at home Depot. They are generally made with about three feet of cable attached. you will have to take the back plate off of the dryer and attach the three leads to the proper termination.
SOURCE: how to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
