Question about Kaz 4100 1 Gallon Humidifier
I've had my Kaz 4100 for about 4 years but rarely used it. Yesterday the motor just quit running on me. What happened can I do anything (with minimal cost) or do I just have to go buy a new one?
Send me the solution please, I tried to disassemble but can make it. oscarrendonc@gmail.com
Posted on Aug 02, 2011
SOURCE:
The Honeywell HCM-6009 humidifier unit no longer turns on. This was an abrupt change--not sure what happened. It was working fine one day, and the next day it was dead. Is there anything I can do to...
Save the time and frustration these units are hard to work on. Make sure there is power to the unit other than that throw it away and buy a new one for $100.
Aug 19, 2011 | Honeywell QuietCare HCM-6009 Humidifier
I have a healthist humidifier model 4100.. I purchased my humidifier on 12/26/09 from Raindew pharmacy. So far I had no problem.But today, when I plugged the apparel, nothing haened, the motor is not...
If you've been using tap water, then you likely have hard water deposits (scale) on the heating element, which will eventually cause it to stop working. Try cleaning it with an overnight vinegar soak, or whatever is suggested in the manual if you have one. Once most of the deposits are gone, it shold work again. In the future, this will not happen if you use distilled (not to be confused with filtered) water. Good luck!
Feb 13, 2011 | Kaz 4100 1 Gallon Humidifier
How do i clean
How do I clean white gritty minerals from under plastic wheel. I took out the three screws, but the wheel will not move. I'm afraid to force it...might crack or break.
Feb 08, 2011 | Kaz 4100 1 Gallon Humidifier
I wanted to clean the inside of the kaz vaporizer and i took the screws out but cant get the gray plastic off help it looks like there is a lot of dried minerals inside help please
I want to clean the white gritty minerals from the fly wheel inside the humidifier. I took the three screws out but the plastic wheel will not move. I'm afraid to force it...might crack or break.
Jan 03, 2011 | Kaz 4100 1 Gallon Humidifier
Lost the manual. Can tap water be used or just purified water.
We have had a separate make for years and just use tap with no problems.It leaves a water mark on the water holder but it cleans off.If you have a water filter already on your tap or a Brita type container with a filter,feel free to use that too.Either way,it will not hurt the humidifier. Good luck! Greg
Aug 13, 2010 | Kaz 4100 1 Gallon Humidifier
What is the voltage 120 of 240?
If it will plug into standard wall socket it is 110 volts. 240 volt plug is different
Jan 27, 2010 | Kaz 4100 1 Gallon Humidifier
I can't see my vapor.
Suspect that you may need to run white vingar through it and clear the atomizer. You should see mist all the time even when the humidity level is reached.
Jan 14, 2010 | Kaz 4100 1 Gallon Humidifier
My humidifier isnt working properly, it is not using any water
Make sure you soak the wic with COLD water and don't ring it out. Make sure when your putting the tank back in that you don't spill any water into the fan vent. If you get even a splash into the vent, it makes that awful loud motor noise. If this happens just let it dry out on it's own(over night). Also try cleaning the wic tray. It tends to get slimmy from the water sitting in it. If you ever see that your tank is empty, wet your wic when you refill it. Make sure you rinse and wet the wic EVERYTIME you refill the tank. The wic dries out fast and can start smelling pretty bad if you don't rine it regularly.
Nov 16, 2008 | Kaz Sesame Street Elmo & Friends...
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Kaz 4100 1 Gallon Humidifier Logo
78 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
