Akai LCT2060 Television Logo
Posted on Jul 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen goes black after 2 seconds
When I turn the Akai LCT2060 on I get a blue screen with channel number showing in 2 seconds the screen goes black.
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Nov 04, 2008
Anonymous
Expert
Level 2:
Answers
286
Questions
Helped
253519
Points
565
This is a mean problem, and I feel for anyone who has it.
This can be caused by a bad power board, a bad main board or a lcd LCD panel.
An authorized repair shop would be able to substitute the main and power boards to find the source of the fault, but you don't have that luxury.
Unless you want to risk paying for an expensive part you don't need, I would suggest you take it to an Akai repair shop.
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
2answers
No picture
I would replace the entire inverter board. Picking and choosing will cost more.
No signal
Call Dish and ask them is there any firmware you need for your tv....they should provide it for you.
Akia lct2070 screen went black and will now shut its self off
You may need new inverters, CCFL's, or your power supply is not [providing regulated 24 volts...
Inverters
CCFL assembly
power supply
We have these Akai boards in stock if you need them.....
My akai lct 2070 screen has two issues one is that about a month ago the screen went black only viewable with a light next to it and now when the tv is turned on it stays on for about 30 seconds before it...
Inverter
power suply
CCFL assembly
One of these boards are causing this problem, we have them in stock if you need them. the tv is programmed to shut down if all circuits are not functioning properly.
Akai LCT2060
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
2answers
Black screen
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
2answers
No picture
Tyler
2answers
AKAI 20 INCH lcd MODEL #LCT2060
This is an indication that one of the components in the screen control sections has a thermal instability problem. This canusually be found using a product called cool mist which is a component cooling spray. This lowers the compenent temperature and allows you to see which component has the problem. Also you may want to if you are able try to use a voltmenter and a schematic to trace the problem down once you know which component is giving you the problem.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
