Before you look at the dryer , check your venting. 80% of all our dryer calls are a result of poor airflow. Vent connector between dryer and main vent or outside wall should be 4" rigid metal or heavy metal flex. Dryer manufacturers consider plastic, vinyl and foil to be improper due to their tendency to crimp and flatten easily. Vent coluld also be stopped up.
Check outside exhaust opening to be sure it is not clogged or otherwise closed. Best way to check vent sometimes is to pull dryer out, remove vent and run a load of clothes. If drying time is significantly better, then venting is your problem.
Whirlpool sells a heavy metal flex vent kit , part #4396028
