Remove nails and disconnect airline. Open door latch and check for back and forth movement of the feed piston. It should move with little force and should have spring tension when you push on the leading edge of the feeder. If very hard to move then most likely orings are swollen or stuck from lack of lubrication or water entering gun. Remove head being carefull not to tear gasket and check piston/ oring for tight fit( the piston will not come all the way out, just enough to repalce oring). If very tight then all orings should be replaced. If just dry, lube with silicone paste or proper oil. Check that the cylinder retracts into body of gun and rather easily pulls back up. Do not use pliers on the the cylinder; it is spring loaded and shuld move with finger pressure. Parts are available at www.toolpartsdirect.com. Good holidays
