Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
The
best advice I can tell you at this point is to go to
tvrepairkits.com
and order the complete convergence kit for your model of TV set, no need to
search and order multiple parts from different sources and pay multiple
shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap
aftermarket or
china made IC’S full pictorial
directions, the thermal paste, resistors, the correct
Pico
fuses, AND free live on-Line tech assistance in case you run into a problem
with the repair. They ship out 2 to 3 day Priority mail, the next day in most
cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Exactly the same thing is happening here :-( We plan to get a repairman in soon.
i have the same problem looks like i am trying to view a blocked cable chanel on each channel, feel like ive tried everything called the company they said take it in for repair soounds to them like a tunning issue
I also have a toshiba 50h81 and takes a while to warm up and each day the picture is getting worse,,also i have a lightning show every now and then what causes this and how much can i get that fixed for??????Brian
I have the same problem with the scrambled picture. I can purchase the capacitor and replace it myself if i can ID it and where it's located on the board. Can you help? RB
I have the same problem with my set, and I called a repair shop and was given an estimate of about seven hundred dollars. Might be worth it to get a new one....
