Precor Error Code 42
Error Code: 42
Manufacturer: Precor
Model: All Models
Error Description:
Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40.
Possible Reason:
Recommended Action:
Lift Position Value Out of Range Precor Error 42
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
SOURCE: How do I replace the
Check this reference guide in video: Precor+elliptical+trainer+change+belt
Hope helps.
