SOURCE: Video not found after finalizing disc on Samsung SC-DC164 DVD Camcorder
Put it back in the Camera and see if it tells you the disc is finalized when it tries to format the disc. If it does then you know for sure it is finalized..
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
SOURCE: dvd player reads no disc and than shows loading
Have you tried other DVD's...you might have a bad one.
If so,,,you may need to clean the laser diode. You'll need cottonless swabs (no lint swabs) and Isopropyl alcohol 99%.
Might be hard to get to, depending on the model, but gently swab the diode lens. Don't saturate it tho.
good luck
