Hi I have a 40lt engal fridge and the battery in the thermostat ran flat. So I went to my local **** Smith chasing a lr44 battery, I did not find that perticular code, however he did give me a battery that he assured me was compatible. After I had installed the battery it constantly flashes cb1 or c61 something along these lines. Does this mean that the battery is not good, or is it something else?
I had a similar issue with an Olympus OM4. It went in for repair but was never resolved. The batteries in my OM1-md last forever! I ended up doing the same remove the batteries after use. I can't remember the configuration, but if the LR44 are two and double stacked, you could use the Lithium equivalent.
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Yes , your fridge can get stuck in defrost mode. If you can locate the thermostat. Sometimes buried behind a panel in the freezer. There's an adjustment screw or trim screw that allows you to advance the timer on the thermostat. Sometimes they stick in the defrost mode. It may happen once and never happen again. If however it does continue you will have to replace that part.
I have never worked on an Engal, so won't attempt to answer your question, BUT I have had very good luck going back to the place I bought something to get owners manuals and wiring diagrams. If they don't have one to give to me, they will normally copy it for me for very little.
