My IP4200 was working fine until yesterday, when I accidently triggered a huge print, and may have pressed the wrong button (or for too long) to cancel printing. Now it accepts my print command, feeds the paper through half way, then stops, with the top light blinking green, slowly. Turning off and on does not help. When I press the middle button the paper shoots through with no problems (but no print) so it is not a jamming issue. The cartridges (originals), which are nearly full, all show non-blinking red lights. I have taken out and replaced each one, in case the printer needs to recognise them again.
As I write, the top light is still blinking slowly, the middle light is on. I haven't noticed any amber lights flashing - always green.
Can you help?
How many times does the flight flash? - thats a error code
is this a alarm / power light?
Please check for torn piece in the carriage which is causing the error
30 results
Next>>
1.
Alarm / Power light flashes orange 10 times consecutively (Duplex Printing Error)
After lighting in green, the power light flashes orange 10 times consecutively (Duplex Printing Error)
2.
Alarm / Power light flashes orange 11 times consecutively (Automatic Print Head Alignment Error)
3.
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
4.
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
5.
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
6.
Alarm / Power light flashes orange 6 times consecutively (Inner Cover Open Error)
7.
Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
8.
Alarm / Power light flashes orange 9 times consecutively (Camera Connection Error)
9.
Alarm / Power light flashes orange 13 times consecutively
10.
Alarm / Power light flashes orange 14 times consecutively
11.
Alarm / Power light flashes orange 15 times consecutively
12.
Alarm / Power light flashes orange 4 times consecutively (Ink is out or ink tank installed incorrectly)
13.
Alarm / Power light flashes orange 7 times consecutively (ink tank installed incorrectly 1680, 1681)
Alarm light flashes orange 7 times consecutively
14.
ERROR: -9672 appears selecting printer in Printer Setup Utility (with AirPort installed)
15.
Alarm / Power light is solid steady orange
16.
Duplex printing is light
17.
ERROR BJ metafile. Cannot execute background printing.
18.
Error No.: 1700 appears on the computer screen
19.
Error No.: 2001 appears on the computer screen
20.
Error No.: 2500 appears on the computer screen
21.
Error No.: 300 appears on the computer screen
22.
ERROR: ...Invalid access to memory location
23.
ERROR: 19 (Mac OS X)
24.
ERROR: Before you can print, you need to select a printer. (Windows Vista/XP/2000)
25.
ERROR: Cannot communicate with printer
26.
ERROR: Canon Easy-WebPrint is not supported by this version of Microsoft Internet Explorer
27.
ERROR: Data left in queue
28.
ERROR: Error writing to LPT1
29.
ERROR: HI-SPEED USB Device Plugged into non-HI-SPEED USB Hub
30.
ERROR: Printer is offline.
CLICK ON ANY OF THE SIMILAR ERROR LINK AND YOU WILL GET THE SOLUTION,,
ANY FURTHER ASSISTANCE REQUIRED PLEASE DO WRITE
ALL THE BEST
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
How to reset Canon MX310
printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold
power button also. Hold both buttons
together for 5 secs.
3. Still holding the power button, release the
stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now
say 'Service Mode').
5. Wait until the power button lights steady
green, then press the stop/reset button three times with a 3 sec space between
each press. On the 3rd press the
indicator should turn steady orange.
6. Press the power button once, (the orange
light should go off).
7. Open the printer and remove both
cartridges. Wait for 10 seconds. Replace the cartridges and close
printer. Wait for 30 seconds.
8. Press the power button, and wait until
printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper,
then ask you to set the language.
10. The page counter is now reset! Enjoy.
Hi Maanita - I have checked, and there is no torn
paper in the carriage. The paper feeds through easily when I press the feed
button.
Regards,
Penny
It's the power light, and it continues to blink green slowly and regularly until I turn it off and back on again. Then it initialises normally.
I just successfully performed a print head alignment - the paper moved through and printed normally during the alignment. I tried to print a document immediately after, and the same problem occurred - it stopped half way and didn't print at all. (I tried printing from two different programmes with the same result)
The problem is fixed! I performed a bottom plate cleaning through the maintenance menu, and it is now printing normally.
