Lego broke the front glass of the LCD........... time for a trip to Best Buy or Circuit City for a new TV. Cost to replace the screen will exceed the cost of a new TV.
Lift the copy bed cover and locate the **** glass (it is about 1" wide and sits on the left of the large glass)
Use a microfiber cloth, and a bit of water, and remove the debris from this **** glass. Make sure it is clean, then clean the white bar on the underside of the top cover (It will sit on that **** glass)
take a blank piece of paper and copy it through the feeder, if you have lines on the page that prints, you need to look harder for a spec on that glass. a small dot will create a line on any document fed through the feeder. A dot on the large glass will print only the dot as the paper is not moving over it.
Yes, thats correct. If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price. New TV is better option.
Unfortunatly no.. you will need to either live with it or replace the entire LCD panel. You can have it repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Whoaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!!!!!!!! No need to da all that. Lift up the Doc feeder and look at the SMALL strip of glass, you will see a dot or something on it, clean w/alcohol. Voila taken care of. the dot ( pen mark, white out, etc...) makes a line because the document is Moving and that dot now looks like a line to the copier. :)
The front main screen polarizer is damaged. Only two options are available for it. 1. Order a replacement panel, which will cost more that what u probably bought the tv for. 2. Buy a new TV.
There is something on the small slit glass. There should be 2 pieces of glass on the copier. One where you place your original, and the other is a small slit glass about a 1/2" width by 9" long. Check the small glass to see if there is anything like a spot of black INK or a dot of white out on there. There is something on the small piece of glass that is causing your line problem.
Hope this helps. Good luck.
Mac
