You can download the manual and the Vivitar Experience software from here.
You don't need the Vivitar software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
SOURCE: Missing Download Disk, Thrown away with Camera wrapping
The CD which came along with Camera Finepix 2800 has been lost and I am unable to work without software. How to get the CD for FUji Fine Pix 2800. Kindly help me in getting the CD
SOURCE: Lost Disk to install
Your software can be downloaded here, directly from HP:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3308694&lc=en&cc=us&dlc=en&submit.y=5&submit.x=9&lang=en&cc=us
Choose your operating system from the list, and download.
Be sure to UNPLUG the webcam from the PC before installing!
ONLY plug it in once the on-screen instructions tell you to do so.
SOURCE: Need icoaster instructions
go to thee web site and click on down load instruction booklet for that product make sure u have the model and serial numbers available you might nedd them , you should find these numbers on the bottom or side of the product it self or on the box if you still have the box the product came in.
SOURCE: i lost my webcam cd installer
Here you can find your webcame based on image and download the driver for your OS.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Just pick the camera that resembles yours the most and click the picture. On the new page click downloads, then choose your OS from the dropdown list. Then select whether you have a 32bit or a 64bit system. In case of Windows 2000 you can only choose language.
After this procedure you'll get a download link for the driver.
SOURCE: I need to set up my tv remote for my new sanyo 50
Here's a link to the manual (I always toss them, too)!
http://us.sanyo.com/dynamic/product/Downloads/DP50749%20OM%20(332--)-45914968.pdf
Hope this helps!
Rate my solution!
