I have a Sharp wireless thermo clock, Atomic Clock. Can't get the "outside" temprature module to work. tried new batteries. Can I purchase a new outlide module?
press,timer/clock ,colon will flash ,enter correct time{i.e. 12:34},press clock/timer again,,all set,if it doesnt work,return it to where you bought it,
sometimes the clock resets after unpluging for a short period.
when you restart / power up note the time it starts at generally 12:00 miday
good luck gbw
Touch STOP/CLEAR pad. Touch TIMER/CLOCK pad. Enter the correct time of day by touching the numbers above in sequence. (for example: for 12:30, touch 1 2 3 0) Touch TIMER/CLOCK pad again.
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
