La Crosse Technology WS9245UBKITCBP wireless temperature station with in Logo
Posted on May 17, 2017
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the receiver. The receiver shows the "bleep" like it is looking for a signal but that shuts off after 2 minutes. We've tried it with the transmitter in close range in the house and in different positions but still no luck. Any suggestions? This was a Christmas present and the givers will soon be asking about it.
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
2answers
Oregon Scientific WMR86A wind sensor does not communicate to the base station. It is a new device, first time assembled.
I believe the wind sensor is a rotating cuff that has a wire which needs to input into the main reader or the wifi unit.if it's the wifi unit you need to check the receiver is picking up the signal.if it's the main readout then check the connection.if it is wireless, you may find a switch on the transmitter to change channel.this may fix the problem, especially if the receiver is near other wireless or bluetooth equipment.
2helpful
My acurite model75321a1 does not tell out side temperature
We would recommend a reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery, and follow the steps below.
  1. Remove the batteries from the outdoor sensor only.
  2. In the outdoor section on the main unit, there will be a "CH" and number 1-3.
  3. If on CH 1, press and hold the channel button on the back of the unit for 5 seconds.
  4. Press and release the channel button one time, it should show CH 2.
    • If it does not change to CH 2, repeat steps 4 and 5.
  5. Press and hold the channel button for 5 seconds.
  6. Press and release the channel button one time, it should show CH 3.
    • If it does not change to CH 3, repeat steps 6 and 7.
  7. Press and hold the channel button for 5 seconds.
  8. Press and release the channel button one time, it should return to CH 1.
    • If it does not change to CH 1, repeat steps 8 and 9.
    ***Regardless of what channel you begin on, clear out each channel by holding the channel button and return to CH 1***
  9. Reinstall batteries in the outdoor sensor.
  10. Press and release the TX button.
  11. Leave both units side by side for up to 30 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected].
Aqua systems wireless weather station. Temperature reading is incorrect and exterior sensor and indoor sensor have different readings even when side by side.
Is yours the colour screen one? I thought I was getting the same readings from both units no matter where I put them, but I put a bag of peas on top of one unit and the temperature and humidity dropped massively so mine seems to be working, even if it didn't seem to be working to begin with. Weird unit, why the two sensors anyway, I dont get it.
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
83helpful
8answers
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
