SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
SOURCE: Can't take pictures with Sony Cybershot
have a look at the memory card on the side of it there should be a slide thats a different colour to the rest of the memory card move it to its second position and try it
SOURCE: unable to see pictures on my sony dsc t70 memory card
Try connecting MS directly to the PC (Via an adapter, if necessary)
SOURCE: Cant download pictures to my computer....
TRY RESTORING YOUR PC TO A TIME BEFORE THIS STARTED, OR COULD BE YOUR FIREWALLS
SOURCE: Sony DSC-T700 PURPLE FLICKER
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
