Turn on your computer. If your computer is already on, then reboot it.
You need to see the initial display screen to get into the BIOS.
Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information.
The majority of Gateway computers use the F1 key.
If, for some reason this does not work, then use the F2.
All of Gateway's desktops use the F1 or F2 keys.
hope this helps
Hi
F2 error is displayed when control won't sense motor to be
rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the
RPS sensor or a bad stator assembly. If the motor rotor spins freely and both
impellers are securely attached then the issue is with the RPS sensor. If the
motor won't rotate then it is the motor rotor that has to be replaced. Hope
this helps...please post back for further assistance.
Daniel
