Question about Necchi 3102 Mechanical Sewing Machine
I cannot release the stop motion knob, it will not release or tighten. How can I get it unjammed? Please help!!!. I have to setup my Mother's old 1939 Singer to wind the bobbin! Luckily, that still works after all these years.
  • Necchi Master
  • 1,564 Answers
Are you sure it's a screw type knob and not a push pull button type?
Posted on Oct 02, 2013
SOURCE:
  • 323 Answers
SOURCE: The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
sewman7
Posted on Dec 29, 2008
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
I removed the hand wheel cover on my Bernina 1001 because the wheel was too tight and now I cant get it to do anything...sew, wind bobbin. Help
With the wheel on you will have a 3 pronged washer, make sure that the screw on the stop motion wheel is unscrewed all the way, put the stop motion wheel back on ans tighten it hand tight only, tighten the screw in the stop motion and see if the stop motion frees off and then tightens again so the machine will work, if it does not take the stop motion wheel of again and move the 3 pronged washer in a different position and put the stop motion wheel back on again
Oct 04, 2013 | Sewing Machines
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
Brother VX-1100 - Stop motion knob will not move, the machine hasn't been used in a while, how do you get the knob to move? Thanks Si
This sounds like there may be some oil that has turned to varnish and is therefore, seizing the stop motion knob in place. The old oil will have to be dissolved unless it has just been overly tightened. With the machine not used in some time, it should be serviced and lubed so it will work like new again.
<Ray>
Nov 05, 2010 | Sewing Machines
Took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Jul 17, 2010 | Sewing Machines
Stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
sewman7
Dec 03, 2008 | Sewing Machines
Brother sewing machine
I have only a cheap one (VX-1100), but when this is happening on mine, the stop-motion knob isn't fully engaged with the balance wheel. They are held together by one being tightened to the other for sewing, loosened for bobbin winding. Michael
Aug 31, 2008 | Sewing Machines
Necchi 3102 Mechanical Sewing Machine Logo
180 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
