Speed Queen CTS90AWN Front Load Washer Logo
Posted on Dec 27, 2010
Model CTS90AWN Speed Queen from Alliance Laundry Systems. The unit shakes / vibrates quite a bit - I have read that this is a common problem. Also leaks a small amount of water from beneath unit (have not yet opened the pedestal to determine the exact location of the leak.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
6020
Points
8
These machine like to be loaded to capacity. Under loading them is the major cause of shaking. Try loading the drum all the way lightly filled but not packed. Another thing to look for is that it was installed properly. It is very important with theses machine that they be leveled properly at install. If this was not done shaking can occur.
2answers
How can i get the agitator off a speed queen modle number AWN412SP111TW01
If its a standard top loader there should be a cap you can pry off on top of agitator. Screw or bolt is under cap.
Speedqueen door light blink
the door interlock has failed
http://www.pwslaundry.com/files/manuals/alliance-manuals/802105.pdf
they call it a Door Latch/Switch Assembly
and i recon yours has failed or overheated {cooked thru use}
Parts diagram
bearing kit try e spares.com
I NEED A MANUAL FOR SPEEDQUEEN TOPLOADER LWS21NW
You can get a manual online from Speed Queens Website( Alliance Laundry)
Hi i have speed queen laundry dry and washer but some of dryers needs parts for this stex17wn4350. possible to forward me prices like for motors pulleys and other thgs...
1. What geographic location? (parts source)
The support company for Speed Queen is Alliance Laundry Systems (Since 1908)
US and Canada Dealers (Pdf files)
http://www.speedqueen.com/home/support/parts-dealers.aspx
For the UK
Do a net search ""Alliance Laundry Systems" +parts +Coin site:.uk"
(the uk after site: above is the domain)
This appears to be a good source in the UK.
http://www.armstrong-laundry.co.uk/spare_parts.html
Thanks for choosing FixYa,
Kelly
My Speed Queen washer shakes and walks during the spin cycle. I have leveled the machine and ajusted the amount of clothes in subsequent loads and it still shakes. How do I solve this? Thank you!
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
2helpful
Who manufactures speed queen dryers
The speed queen is manufactured by "Alliance Laundry Systems"
Based in the U.S.,A.
If this helped please give me a four star rating if you liked the answer.
  • Thanks for using Fixya!!!
Top Speed Washing Machines Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
