1996 BMW 318 Logo
Posted on Sep 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BMW I Have recently purchased a BMW 318i 1993 model estate, it has very light steering but no signs of ware and tare on the steering or any other components related to the steering. The MOT is only 2 months old. Any ideas before I have to take it in to a garage. I am a pensioner & cost is obviously a factor. Kind regards S. Georgiou.
kays
Level 3:
Genius:
  • BMW Master 1,179 Answers
  • Posted on Oct 01, 2017
kays
BMW Master
Level 3:
Genius:
Answers
1179
Questions
0
Helped
311747
Points
1715
Hi
whats the problem with the car?
steering being light is not a fault.
thank you
1 Related Answer
Anonymous
  • 16 Answers
  • Posted on Mar 12, 2009
SOURCE: replace ignition lock cylinder 1996 BMW 318i with 1995 BMW
no you can not
Why my 1993 BMW 318i won't start?
Try resetting your inertial safety switch (especially if the car was bumped or in an accident recently).
I have a 1993 BMW 318i. It makes a loud grinding/rasping noise, which I can feel in the steering wheel, when I turn to the right of left. Although the car has power steering it is also very unresponsive/...
Replace power steering rack and power steering pump. But first check fluid level. No fluid in reservoir can mimick same problem. Take off air box to adequately see level.
2helpful
Just want to find out...does bmw 318i e36 have a timing belt or timing chain?
There are 2 engines used on the 318i. One has a chain the other a belt. The M40B18(1990-1993) uses a cam belt and the M43B18(1993-1998) a chain.
2answers
How do i remove the tail light on a 318I 1996 BMW? Tail light is not working but light bulb are good.
could be the brake sensor switch down below by steering column/brake pedal.
2answers
Need Fuse Map Diagram BMW 318i 1993
check the internet for a bmw e36 ETM ( electronic troubleshooting manual) everything you need is there.
3helpful
1994 BMW 318i Fuse Box layout
the fuses u are looking for are as follows:
From the top left first row its# 4
then the bottom row its # 19
I also wanted to point out. from 1989 to 1996 the brake switch was the common failure for bmw's
the series it included were 318i, 525-540i, and all 7 series. if the fuses dont fix it.. its the switch
located under a panel u need remove on the drivers side on the steering collum
3helpful
2answers
1993 318i windows and sunroof appear to have no power
I have a 1993 bmw 318i and the same problem..no power to the windows or sunroof and no lights on any of the window or sunroof switches.The ANSWER is take the kick panel of the driver side locate the blue relay next to the orange or brown relay.Take the blue relay out and either replace it or take the blue cap off the relay and check the solder to all pins.There is one or more pins where the solder has crack..just buy a soldering gun and some solder .015 diameter and re solder all the cracked solder on the pins and it is back to normal.
Steering column 1992 BMW 318i
Go to the dealer parts dept and ask for them to print a copy of the exploded parts diagram.
Bmw 318i air con switch
the light should be on when air con is working. only works when the blower is on ,ie heater blower switch on=air con light lit up = aircon working.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
