SOURCE: singer scholastic sewing machine will
The flat part of the needle goes toward the back. You may also be using the wrong size needle for your project. Make sure the bobbin is threaded correctly. The bobbin may also need the tension adjusted, small screw on the bobbin case. You may have something lodged, try unthreading the bobbib and moving the large knob on the side back and forth with only the top thread. If there is broken thread etc under there you should be able to see and remove it. I have also used a blow-dryer to blow out dust and fuzz.Remember to oil your machine using the correct oil. Be careful to not force the fabric by either pulling it tight or holding it so that the feed is being forced. There are tutorials at the Singer site if none of this helps you.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
