Contributor
- Posted on Dec 27, 2010
Re: Our Maytag MDB9100AWB is 5 years old. Have had...
There are three typical causes of chronic cloudiness on glassware/dishes.
- The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
- Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
- Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
