JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
Posted on Dec 27, 2010
The sound suddenly went out on our JVC HD52Z575, that is about seven years old and otherwise works well.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
153
Points
The sound board is gone.... it's not worth it to repair. Just use the analog audio out from the TV to the external audio system. that's what I do on mine.
JVC TV mod HD52z575 SE#07080014. After I turn tv on within seconds The "menu" dark-box appears on the screen how can I take it off
If it's just a black box nothing in it,it sounds like you have tha closed caption decoder on check you instruction book for directions how to turn it on/off it's probably set on a text mode.
Have a jvc hd52Z575 - can't get the closed caption to work. Have checked the menu-cc is on-set for closed caption-cc1. Per manual menu is set correctly,
If your using component input or a/v input, the cc in the set is not used, only using the cable input jack will you be able to use cc. You have to activate it through your cable box or satellite receiver if your using either one of those.
1helpful
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Our LT42DV8BJ JVC tv went off and wouldn't switch back on
This my be the power supply board. Capacitors will get leakey and wont let the set start up.
Jvc hd52z575. Just replaced bulb and can't get the audio to work through Tv Help please!
first check to make sure the red and white cables are plugged in, then go into the menue , under audio hilight the tv speakers, make sure they are on, if they are, make sure the mute button wasnt turned on
2answers
JVC DVD player only plays sound but no picture
please check the vedio cabele for disconnection (the yellow coloured one).if the cable is RCA ,use your audio cable to check this.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
