Nfive CardFive Classic Edition (C1700) Logo
Posted on Dec 27, 2010
I cannot find the licence on my system and I don't know the file name to search for it
2answers
Cannot change ups mge galaxy 300 licence deadline
you can send me the executable file at [email protected] AND IWILL SEE IF THERE anything to do
tip
How to find a lost file on your Computer?
Today tip will help you to enjoy the quick and easy way to find lost files on your computer. Here I recommends you, try to search a file with its file extensions (for example for word file, type *.doc, Excel *.xls, Acrobat *.pdf, *.ppt and *.exe for executable files. If you don't know the name of file but know that it contains a string of text then try to search for files containing specific text, type the text you want to find from any file or folder. This is time taking process but creates very precise result. In Look in, click the drive, folder, or network you want to search. To save time, always select the specified drive or location instead of whole computer.
Click Start Button, point to Search, and then click For File or Folders, a Search Results dialog box will appear. In Search for files or folders named, type the file name or folder name you want to find in containing text.
To specify additional search criteria, click Search Options, and then click one or more of the following options to narrow your search:
  • Select Date to look for files that were created or modified on or between specific dates.
  • Select Type to look for files of a specific type, such as a text or WordPad document.
  • Select Size to look for files of a specific size.
  • Select Advanced Options to specify additional search criteria.
  • Click Search now.
I need pci sound card driver but i don't know the module
Good Day,
With your problem, you may want to download a software called ASTRA32, with this link, http://www.astra32.com/files/astra32setup.exe After downloading, please install it,(just follow on screen instructions) then RUN it. It may take a while to run it the first time (depending on your system configuration). After a while, you will se a windows listing all your system information, driver names, etc.
Just click on the button that says "DRIVERS" with an exclamation point. Here it will show you all hardware which does not have the correct drivers installed, which in your case no driver has been installed yet. Just browse down on the right window pane to see the complete hardware name of your sound card. It will be listed there as "Problem Device" and just look for the device name. After you have known the device name, you can either go to the device manufacturers website or search for the drivers using any search engine of you choice, such as Google.
Hope this helps you. and thank you for using Fixya.
My computer have no VGA driver
Hi smakjames,
to help you I need you to search for me the name of your VGA card. If you don't know how to search follow these steps:
Start -> Control Panel -> System -> Hardware -> Device management -> Video Card
You can see the name of your video card.
Regards
I would like to know how to change my back up loc from one spot to anther spot say from a back up A to B please as I want back to a flash stick . regardes ...
Is a tricky quest.Let see.You need to remember where you back up your files.Then you can retrieve them.If you don,t remember where are the back up try the explorer search if you use Windows as your OS.Also you can search by the name you "named' the back up.If you back up the files in the stick just plug it and search for those files.
If you need more help come back.Post / thumbs / testimonial are welcome!
2answers
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
3helpful
I want ot install ansys 11 on my compuer can u
install normaly ansys. then launch the "setup licence" it will look for a licence file in a folder named "Licencing".
The licence file you can get it from a folder named "magnitude" where you can find aansys.dat file. you open it with notepad and then change the name of your computer and an adress. you will get these information from executing "WinHostId".
when finshing this changement, you execute "keygen" this will ran a licence.dat file. You copy it and you paste it in the licencing file. and wait for the end of installation.
this is not all :) you have to go to the environmental variables and create a new one:
ANSYSLMD_LICENSE_FILE = 1055@host
where host is the name of your computer
click ok and enjoy Ansys
6helpful
2answers
Downloaded a movie to my n70 but it would not play, it keeps saying unknown file format. added a windows media player and it still would not play...
well the operating system of nokia n 70 is symbian not windows so windows media player doesnot work on it and u never add a software u always install it..
here is what u have to do
1.Download a software name "Smart Movie"
2.Now use a video convertor like "any video convertor" for converting the movie to avi format of the resolution of ur phones screen.
3.Now install smart movie
4.Add movie to ur phone(converted one)
5.Rescan file system in smart movie.
Aug 11, 2009 • Cell Phones
I have microsoft xcell 2003 after I finish my work I cannot find in file the send to so I may email workd done to someone I tglried customs but it keep asking or dhows for fax set up?
You can go to file and save as in Excel and see the path...But if your session has already closed...And you know the name of the file you can Search for that file....Click on Start and Search....Select all Files and folders...Type in All or Part of the File Name....And Search.
Top Nfive Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Nfive Computer and Internet Expert? Answer questions, earn points and help others
