Buffalo Technology Buffalo AirStation Broadband Router AP Wireless (WBR-G54) Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
Bruce Robin
Level 2:
  • Expert 300 Answers
  • Posted on Dec 27, 2010
Bruce Robin
Expert
Level 2:
Answers
300
Questions
0
Helped
211896
Points
855
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Unable to locate WEP key. Adding device to wireless network. Using WHR HP G54 model
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
1helpful
2answers
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
1helpful
2answers
Will not let me on http://192.168.1.1. to config the security
go to start>>run. type in cmd and press enter.
type in ping 192.168.1.1 and press enter
you should be able to see the return message as reply from 192.168.1.1 and the time.
if you see timeout then the unit is not connected to your computer.
if it is connected then try without the http:// just the 192.168.1.1 in the brower address line.
1helpful
NINTENDO WII CANT FIND ACCESS POINT (BUFFALO WBMR-G54)
defenately call nintendo, i hooked up ours and i think the access point or brand is not compatable with the wii, something with the mgz, they will let you know.....wii has problems with an estimate of 6 or 7 diffrent models.....and make sure it's on the wek setting tho it's a bit picky, then again with all it does on line it's just trying to protect you.....shia
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Im a computer dummy ive just bought a wbmr-g54 and i havent a clue what to do
1. Install Software that Came with The Product. Usually it has on-screen instructions.
2. Hook up wbmr-g54 to your computer. ( Ethernet Cable to Modem, And Ethernet Cable to Computer. If you have a wireless thingy majig for your computer then that would detect your router already.)
3.Set up Internet Security, and Firewall.
4. Get up onto internet and Surf it like its Teahupoo.
3answers
Reinsalled windows xp on toshiba notebook -- now wireless won't work.
Hi Matt,
When you try to connect wirelessly to your network did get any pop up message like asking you for a network key WPA/WEP? if your wireless network is security enabled then you need to enter the security settings again on the computer since you re-installed XP the security settings that was saved previously was also wiped out.
May I know the exact model number of wireless router/access point that your trying to connect your laptop so that I can provide you with instructions on how to retrieve the security key.
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
