Comcast uses at least 11 different remote controls. I referred to the manuals listed on their
remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
- Turn on the TV.
- Press the TV button once.
- Press and hold the Setup button until the TV button blinks twice, then release Setup.
- Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter
an invalid code, the TV button will produce one long flash and the
remote control will exit the program mode.
- Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
- Turn on the TV.
- Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
- Press 9-9-1. The TV light will blink twice.
- Press and release the digit 1. The TV key will blink twice. Press the Power key.
- Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous
times until the remote control finds the right code in its library. Stop when the TV turns off.
- When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
- Turn on the TV.
- Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter
- Turn on the TV.
- Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous
Comcast Digital Transport Adapter (DTA)Sylvania LCD TV codes:
