The power switch will turn the power off and clear the buffer, then when you turn it on again, it resets to it normal settings. Check the links above for more specific troubleshooting.
This sounds like an issue with either the toner cartridge or the drum unit. Have either of these consumables been changed recently? This should help identify the likely cause.
If the drum has been changed recently I would recommend cleaning the corona wire. If however the toner has been changed there isn't masses I can recommend in terms of trouble shooting. it may however be worth running off 15-30 pages in the hope of pulling the toner through.
Failing this I would recommend calling Brother technical support in case the issue is hardware related and not the fault of a consumable.
Yeah, right. This may not apply, but if you look at the cartridge from the top, on the right side there's a sensor that knows how much toner is in the cartridge. It's a little optical hole like about 1/4-3/8 inch. If you put a piece of black tape over the hole, the printer thinks the cartridge is new :-)
1.Rotate the toner bottom.
2.Open the hopper cover(located in the right side on display) and fit the b oss on the trip of the toner bottle in the grove of the toner supply mouth.
3.Pull the black shutter of the body to the right.Keep pulling until the shutter stops.
4.Pull the shutter of the toner bottle to the right.Toner will be supplied from the toner bootle to the hopper.Tap on the bottom of the toner bottle to make sure that all toner has moved to the hopper.
5.Push the machine shutter to the left until it stops.
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
