SOURCE: Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
SOURCE: my jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
SOURCE: I have a Jura Impressa E85 purchased in 2006. The
This sometimes happens when after cleaning the machine. I will explain: The beans have a natural oil on them as you know, that also helps coat the hopper for beans to fall. Sometimes when cleaning the machine, the natural oil that is built up around the hopper is not there. Once you brew a cup sometimes the light will go off on its on. If the beans by shaking the machine will not drop down, try using a wooden spoon and help get them going. Other way, is cleaning out the beans completely and then spaying some PAM (used for cooking). What I also did was locate the complete manual for you to download and read page 21 in the trouble shooting area. Here is the link you can copy and paste and put in your browser.
http://www.uk.jura.com/home_uk_x/service_support/download_manual_jura_impressa_e80_e85_english.pdf
I hope this helps you, and please rate my free advice accordingly , thanks Mike
