Technics SL-BD20D Turntable Logo
Posted on Dec 27, 2010
Hii ahve aSL-D210 technics Turntable , v old ! .. i ahve linked up to a cambridge Pre amp - but i think that the ground wire is missing on the turnable hence a buzzing noise when the turntable is on . the pre amp has a ground terminal , does anyone know where i put hte ground wire in the back of the turntable . or does anyone have acopy of the user manual for this old deck ?
3 Related Answers
Anonymous
  • 8546 Answers
  • Posted on Mar 04, 2011
SOURCE: I have a Technics Quartz SL-10 Direct Drive
Technics Preamps on eBay:
http://shop.ebay.com/i.html?_nkw=preamp+technics&_sacat=0&_odkw=preamp+technics&_osacat=0&_trksid=p3286.c0.m270.l1313&_rdc=1
There are, of course, many non-Technics PHONO preamps out there.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
If you already have the central receiver and amplification part nailed down you really only need a Phono Preamp to boost and shape the output of the Phono Cartridge. Otherwise you're paying for source switching, volume and tones controls you don't need.
kerguney
Kazim ERGUNEY
  • 577 Answers
  • Posted on Jun 22, 2011
SOURCE: I dont have the orginal
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Anonymous
    • 8546 Answers
    • Posted on Sep 17, 2011
    SOURCE: I have a 25 year
    Web search "hum on turntable with ground" for various techniques to analyze it.
    1helpful
    2answers
    Crosley turntable ground
    If it is not equipped with ground wiring and sockets etc., it dont need it..
    I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
    Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
    Poor sound quality from a technics SL-D210
    Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
    2helpful
    I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
    Hope this helps!
    Technics turntable has a lopt of static. no
    run or rap a cable around both the phones ie red & white then run it to the GND. on the mixer or amp witch ever.failing that put a new ground wire in the turntable.when you take it apart you'll see the old one just crimp a new wire on to the old one,bob's you're uncle
    Low volume through amplifier
    Turntables generate a very low signal. Phono inputs on receivers containa pre-amp section to boost the signal to "line level" or the same level as other audio devices. I would suspect that you need to add that pre-amp section. Phono preamps are available for around $20 or so and are inserted between the turntable and the standard audio input on the receiver or amp.
    Hope this helps,
    Dan
    3answers
    you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
    Buzz....hum problem from turntable....
    Did you ground the turntable? Most of them have a ground wire located somewhere that connects to a screw on your electrical outlet. You could be getting hum from your pre-amp if it is a low quality one. Try unhooking the pre-amp, if that is the problem you won't hear the hum. If the turntable ground is the problem you won't hear music with no pre-amp but you will still hear the hum.
    Very low sound from old turntable
    You need to run that black wire to ground, perhaps a screw on your electrical outlet. You also need a pre-amp with your turntable, I use the mcm 40-630 you can find it many places for sale.
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Kolbrun...
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
