Question about Honda Electrical Supplies
I have a Honda gx 390 that powers a generator, it starts and runs fine for about 25 minutes and then just cuts out, as though I have switched it off. I have to wait a couple of hours before it starts again, starting is easy and it runs beautifully for 25 mins ....... I have changed the oil, there is a low oil warning cutout fitted. If there is too much oil in the engine would this cause the engine to cut out ?
  • 43,501 Answers
This engine has a high temperature cutoff that has probably gone bad...
Check it out here
http://www.tradebit.com/filedetail.php/3070770-gx390-honda-13-hp-engine-parts-manual
You also can download the manual from this site...
heatman101
Posted on Dec 30, 2010
SOURCE:
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
I have an older model Powermate 8125 watt generator with a Honda GX 390 engine. The unit has been setting up for 4 years so I disassembled the carburetor and soaked it in carb acid. The main jet was c
Clean all the ports and jets with some torch tip cleaners or mechanics wire cut at an angle to be sharp.
Make sur ethe fuel filter is not clogged, or the sreen in the tank.
Also empty the tank and dry it out, then add fresh fuel as gasoline goes bad.
Apr 18, 2013 | Horizontal OHV Engine 390cc, GX Series,...
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Mar 22, 2009 | Electrical Supplies
Electrical Supplies Logo
316 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
