Question about Lenovo 3000 J Series 1.80G VBE PC Desktop
I have a Lenovo 3000 J Series XP Professional Service Pack 3 system, with a Seagate ST3160815A Barracuda 160 gig hard drive, with an ATA-100 interface. If I upgrade to an SATA hard drive with 500 gig or more, does the motherboard support the SATA interface? Or would I need to add on an SATA interface card? Thank you.
SOURCE:
  • 18 Answers
SOURCE: graphics upgrade for lenovo 3000 K100
did you install the drivers that came with the radeon card... if not your going to have to go to the manufaturers website and get it for the version of windows you have.
Posted on Sep 26, 2008
Joed911
  • 4338 Answers
SOURCE: Formating My Lenovo 3000 J Series Tower
Try to boot a different cd, to determine whether the drive is bad or if the cd is bad. If it is the drive, you can try cleaning it or replacing it. If it is the XP cd, borrow one fro a friend and use your license, which should be on you unit.
The drivers could be down loaded from the Lenovo/IBM web site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 28, 2008
  • 909 Answers
SOURCE: Avast! BART CD vs Lenovo 3000 n200
You will likely have to go through and create another boot disk, but this time, include the drivers that are going to be needed for SATA and your NIC. I have used an older version, but you should be able to include the drivers, and auto install / config then reburn the CD.
Posted on Nov 02, 2009
SOURCE: cd/DVD drive not recognized in BIOS (Lenovo 3000/n100)
replace the drive and check
Posted on Nov 28, 2009
I've been noticing a squeaking sound intermittently
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
Aug 16, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
Can not read
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 05, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
I want to detect driver Thanks
There is _NO_ need for any additional device-driver -- Windows "natively" supports all disk-drives.
Dec 17, 2010 | Seagate Barracuda 7200.10 ST3160815A -...
How many times a harddisk can be formatted?
The ram, processor and the motherboard will not be affected, but the hard disk will be eventually. The hard drive will be affected but in a slight way. Try to make a recover image for your O.S.
Mar 14, 2010 | Seagate Barracuda 7200.10 ST3160815A -...
How to read date codes
date codes are usually only 4 characters long so this one is the 48th week of 2007 the last 4 maybe the day of the week.
Dec 14, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate hard drive moved from one computer to another won`t boot
Now this is just my opinion but i tried to do the same thing one time and it would not work so I was left with one choice. Do a fresh install, I bought a second hdd and did a fresh install then plugged my original hdd in as a secondary so I could still access my old files.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 12, 2018 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Lenovo 3000 J Series 1.80G VBE PC Desktop Logo
70 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
