Usually, just plugging in the mp3 player to the computer via usb cable will install the driver automatically on the computer. Make sure you have an internet connection on that computer you are connecting your mp3 player to.
Was there a CD with the mp3 player? If there was, the driver is probably there, and all you need to do is install the CD on your computer.
After searching the Archos website, I could not find the drivers for any of the mp3 players unfortunately. If the problem persists, you should tell Archos you have the "Archos 3Cam Vision Mp3 Player" as your product.
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. Image 2. Click Device Manager on the left pane. Image
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Well, one thing u need to know is that Archos 3 vision cant support all file formats and codecs. U need to transcode video files to compatible format with Archos 3 vision. I recommend u Pavtube Video Converter(http://www.pavtube.com/video_converter/) which can transcode between any video files, and it still offers u foramt presets for Archos.
Unfrotunately there appears to be NOTHING. I have checked the Archos website but they simplt don't have an online manual.
e-mails to their tech support remain unaanswered (about video file format and mpg playback getting out of sync.)
I hope it is is not the case that they are a French company and treat their Enlish speaking customers with utter contempt but sadly this is what comes across. Customer supper/user documentation etc. is thin on the ground.
When exploring the player in My Computer on the PC, before disconnecting always
go through the icon "safely remove hardware'' in the right corner on the computer's screen below.
