It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
OK - make sure the washer is level. Hoover makes it clear during installation that it is to be level. Also the drum support frame should have some springs that could be stretched. If so they would have to be replaced.
Thanks: the machine is level but still dancing around, i will look at the springs.Is there a main bearing or bush that can be replaced on main spindle (hoover plus lath100arv)
Yes, they sell a bearing kit for the drum, but that problem is uncommon though unless you have a very old machine. Just think simple things first. Most people tend to think everything is a major problem and usually it is not.
Only 4 towels, can it be a bearing problem there is a noice when spinning cycle start How do i replace bearing (manual)
