xheli 3 Ch Syma S006 Alloy Shark RC Remote Control Metal Frame Helicopter Logo
Posted on Dec 27, 2010
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New batteries in remote controller, LED comes on steady orange when switched on. Helicopter does not respond to any input on the controller. Is there a way to calibrate controller to model or do I have a faulty toy? Instruction manual offers no problem solving options and is in broken english.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
848
Points
Try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
  • neca_florida Jan 31, 2011
    I thought this was the answer to my exact same problem. While it DID synch somehow (blinking lights stabilized) rotors still won't turn.
Jake Valdez
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 28, 2015
Jake Valdez
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8332
Points
It still will not work
User guide for Craig portable power bank model # cma3121a
Craig Electronics Inc
Portable Power Bank with Dual USB Charging Port (3400mAh) CMA3121a Features & Specs Best Replica Watches
  • Quickly Recharge any USB Powered Device such as Tablet, Smartphone and iPad
  • Stylish blue LED power indicator
  • LED light indicates Battery level
  • Built-in TWO Full size USB ports for any device charging via USB port simultaneously
  • Charges Two mobile devices at the same time
  • Scratch resistant UV coating
  • 3400mAh, One Max. 2.1A Output, One 1A Output
  • Available in Colors
ASME B16.5 Accessories Included •Micro USB to Full Size USB Cable
•Mini USB to Full Size USB Cable
My syma s107 isnt responding to my controler
change the batteries in remote controller,,sure for charging indication in flying kit s107,,otherwise describe the fault completely to me
S107 charger light stays red all the time, doesn't change to green.
Check the batteries are new or in good condition. Also charging time is approx. 30 mins check in the manual how long charge time is. We also have replacement USB mini chargers available.
Kind regards, Julian.
rccontrolfreak.co.uk
7helpful
I can't seem to charge my S107 helicopter. I plug the USB charging cable into my computer, and then the helicopter itself, but have no indication that it is charging. Should I see a light on the...
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
I brought a new syma s006 alooy shark rc heli and
Your should exchange the product at the store you bought it from for another one. the problem lies inside the syma. it must have been a defect that the company did not notice.
2answers
Spinning syma s006 doesnt take off
the tail rotor keeps it from spinning thats its job
1helpful
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Top xheli Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a xheli Toy Expert? Answer questions, earn points and help others
