Is the plastic battery tag broken off? It is located below the try me battery terminal. If it is, try removing it with a tweezer or a thin blade. You can also remove the 4 phillips screws from the back of the watch and carefully remove the back cover. Try not to pull on any of the wires. You can see the broken plastic piece. Once you remove it and put the watch back together, it should start working right away.
