Why would any 8 year old computer be in warranty
love to hear that.
july 2010\ (first ones are 2009) carbon dated by me...
you posted 7 years later on this< why:?
lots of older PC the memories are not made, DDR1.
luck you its 3s.
#1 maker here.
try kingstone dot com
see none there.
leaving only used, and is real hard to find a match.
if you tech cant fix you PC then it cant be fixed can it.
he gave up. I know why, but he did.
he is smart,, is why
the correct path is a new or newer used PC
this is the only path
why, because to fix yours costs more. see.
here is your ram spec
*32-bit operating systems cannot address a full 4.0 GB of memory.
kingson , links
CQ532OY
its a DESKTOP, luck you its not obsolete like on many older compaqs
ever like use goggle , i gave up at #1 kingston,
http://www.memorystock.com/memory/CompaqPresarioCQ5320Y.html
https://www.amazon.com/Memory-HP-Compaq-Presario-CQ5320Y-DDR3-10600/dp/B009BRRY66
here you shop
https://duckduckgo.com/?q=CQ532OY+%2C+memory&ia=web
SOURCE: i bought 1 GB of Ram ddr 400 for my dell dimension 2400
it might be not compatible.
Do you have the older memory inserted? If yes is it the same speed as the new one you bought?
Is your laptop front side bus capable of a speed of 400 Mhz?
Try to remove the old Ram and use the new one only!
Yeah dude, I had the same problem with my DELL. If you install more ram, sometimes (even though it has the slots) the computer can't handle it. Did you try removing the ram you added? It may work. Other thing is that you may have loose cables from the power supply.
SOURCE: upgrade memory
ur computer has an expandable memory Max of 128 MB> anything more than that will be too powerful for ur computer's motherboard> upgrading the memory means u need a new motherboard and if possible a new processor too
