Radio Communications Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a motorola rdm2070d radio and am trying to turn the keypad tone back on
eradiostore
Level 3:
  • Radio Commun... Master 1,672 Answers
  • Posted on Dec 28, 2010
eradiostore
Level 3:
Answers
1672
Questions
0
Helped
797137
Points
4248
Keypad Beeps
Keypad Beeps can be enabled/disabled by
short pressing SB2 button (until radio 'chirps')
while turning ON the radio.
Here is a link to the user guide: http://www.astracomm.com/media/pdf/RDX_Display.pdf
Best regards.
2answers
Radio Communications - Can you replace the plastic sleeve covering of the Motorola RDM2070d antenna?
they are available on eBay for $6.00
you can look online there are several vendors.
google Motorola RDM2070d antenna
good luck
What radios are compatable with motorola rdm2070d
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
I just want to know how to clone the motorola rdm2070d
You will need the RLN6303 RDX Radio to Radio Cloning Cable, or two drop-in chargers, or the multi-unit charge tray. Instructions for cloning are on page 51 of the user guide: http://www.weatherconnection.com/manuals/RDV5100.pdf Best regards.
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
6helpful
3answers
Program motorola rdm2070d need to program
The RDM2070D is non-programmable. It operated on pre-selected frequencies. (This radio belongs to a major corporation, and is not intended for use outside their company.)
2helpful
2answers
Vibrate
Press and hold the minus button while turning on your radio to turn on or off your keypad tones.
To turn the roger beep on or off, hold in the plus button while turning on the radio.
Here's a link to the manual direct.motorola.com/ENS/T6500%20Series%20User%20Manual.pdf
2helpful
4answers
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
