What connection , you never said once wifi?
its a wifi router but has 2 ways to connect see?
ive never seen a wireless only router ever,
wired only modem yes
wired and wireless is par, for sure. both are there.
so what OS is this,XP?
why not use the Ethernet cable to the router ($3 cable) 1foot to 100 meters. long. you pick one.
then it works, and play with wifi later. gee?
WIFI is fragile technology. ( a fact)
who owns said router, you or ISP
if you ,do you have the password to it>?
the manual on it shows the default password,
mine new was admin (null) means no pw.
if ISP owns it the use a long secret PW.
this is not the wifi pw its to the web page inside said router. config pages it is called.
so what router is that tell the help the model we can work from there
do other PC work here
do other CELL connect.
all if this is easy to do.
ssid name
encryption mode.
password. for wifi.
more , so if using wifi
do other computer connect ok
or all cell phones.
if not the router is setup wrong
or your using the wrong credentials.
it must be setup correctly or the wifi will work.
google how to setup wife yet.
My routers all have gigalan, and wifi. both.
so all can be connected 2 ways.
wired or wireless.
wire is super simple, wireless not.
tell more get more,
tell what router you have and if you own it.
if the ISP owns it that means its locked.
and only THEY can tell you the wifi rules.
ssid name,
encrypt mode.
password.
some ISP put sticker on the rear of the router. with these locked in facts.
there are vast routers, used, even comcast.
not one can i guess.
the book on it, is free.,
if it has the default password in to router,
we can dig that up, its in PDF on that unstated router.
for sure, if it fails it means its locked out by comcast
good luck.
SOURCE: Wireless internet connection
You haven't specified if the host computer is able to access the internet. Ip Address confict can be one of the reasons why the laptop isnt able to connect and we can have a series of reasons why we have this IP Address conflict - 1) There is no wireless encryption defined. So, we have neighbors connecting to the wireless network causing IP Address conflicts. 2) The laptop is not able to renew the IP Address after the lease expires. This can mostly be resolved by restarting the computer and in certain cases flusing the TCP/IP stack. 3) There is a static IP Address assigned to the laptop in the router's DHCP range which is conflicting with the host computer. I would suggest you may initiate a chat with me or anyone else who has expertise in routers to get this successfully resolved. That would definitely save your time. Good luck
SOURCE: Laptop not picking up Wireless Routers
Firstly check that it is installed by going into Device Manager.
Goto START - SETTINGS - CONTROL PANEL - SYSTEM - DEVICE MANAGER
Look at the list, If you see your card there with a yellow question mark, or a red exclamation mark then it has an issue.
Firstly unistall the device by right clicking it and select Unistall.
Then reboot and Windows will detect the card again and reinstall the drivers for it.
Check back in Device Manager to see if it is still the same. If so, it is possible it is a hardware failure and would need to be replaced.
Beofre you get to that stage though, turn off the laptop, remove the card (it will be underneath under a panel and will have 2 wires connecting to it) then put it back in making sure to push it into the slot correctly. You do not need to remove the wires to do this, and the card does not need to come all the way out.
Post back if you are still having issues.
SOURCE: Internet connection
just remove all the connections & join it...remove proxies & firewalls...in ip configuration...
SOURCE: HP Pavilion tx 1000 tablet
Guru j/k and I spent several hours last night on this problem. We Instant Messaged on Skype and finally figured out that an old expired copy of Norton Security Suite was the cause of the problem, once removed, no mor problem. Guru is the man. He was pleasant, persistent and knowledgable. I highly recommend your service. If the need arrises, I will contact you guys first.
